car's resonant frequency
  • 2
get a cheap Radio shack SPL meter, BASS CD test CD with known freq on each track. Step One outside the car. Set the volume to one spot. play each freq and note the SPL @ 1 meter. So you get a curve on a graph. Like 20hz- 90db,25hz-92db,30hz-93db. Now put the sub in your car and keep the volume the same. Do the testing again. You will see the peak. There might be more than 1. After your done take the incar response and deduct the out of car response from it . Like so 20hz-97bd[incar] - 20hz-90bd[out] give you 7db of transfer function boost
439
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
768
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
631
loud_drums
loud_drums
Mesa, AZ
chris229
SPLBassJunkie
    May 21, 2024
    May 20, 2024
