It's not quite as cold here as it is for you, but it gets quite cold here.
On really cold days my screen will not be as sensitive on the touch screen for the first ~5 minutes or so. Other then that, I've had no problems with the cold.
That's good to know. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Saving up for the parts should give me enough time to learn how to build a computer, as I've never done it before.dont wire the start up control like i did then. i wired mine to were the computer boots when remote started. lets say you dont have a remote start. when you crank to start the car/computer the computer will boot up. But in the cold weather the HDD wont get detected. so i say install a switch to the startup controller,its easy you just hook up a switch to the ignition wire coming to the startupcontroller, like yo do on stereos only diferance is on a stereo you put the switch on the remote wire.
now with that switch your carputer wont turn on imediately, that gives you time for your car to warm up a bit then hit that switch and bam it will boot fine, or some people have made their own tempreture sensors to heat up the hdd to a certain temp to keep it stable(i dont really know how to do that)
