Southeast Region Carl Casper Show Louisville KY
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
I knocked a hole in the bottom of my rear door rails the size of the hole in your fender ben! I'm bondo-ing it now and repainting it //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Your truck looks so pretty too! I guess you're good at disguising what's underneath:laugh:
My truck needs a waxing so bad. If anybody volunteers to wax it I'll give them free dB's.
you'll need to wax it with this :
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
my truck wont be there unless i can find an amp! my 3000 is going back to jacob tomorrow.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif. might be able to get a memphis mcd1500 but it is not 1 ohm stable and i cant risk fryin it because it owuldnt be mine.. 15" nightshade with only 700 watts = //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i wont be there unless i can find an amp! my 3000 is going back to jacob tomorrow.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif. might be able to get a memphis mcd1500 but it is not 1 ohm stable and i cant risk fryin it because it owuldnt be mine.. 15" nightshade with only 700 watts = //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i've got a Autotek MM 1400 you can use if you need to. Might not be much help since its 1 ohm too.
i might take you up on that.. i really just want to get my feet in the door in competing and i may be able to run S1 with that...
You can run S1 with the 3000 too. How much current you're pulling and what kind of score you can put up w/ a low current draw is what makes people successful in S1. Take the amp, you'll have fun man.
What all do I need to run that class? I will be wearin a shirt for my dealers business to kind of help promote him and will have the business cards as well.. He said somethin about that might affect my class?
well shirts wont be done unfortunately but since rules have changed so much it might not matter anymore i did find out the only fuse that matters is the one from last battery to amp..
If you're sponsored you cannot run an amateur class.
2000LaDe
2000LaDe
Lafayette, IN
tommyk90
