Car Stereo Not Working
chiaxi2002
All the fuses seem to be in working order unless I missed one. I know there isn't anything wrong with the stereo because it does the same thing to my other decks. It does receive power because it can still eject cds, but just doesn't seem to power up all the way. You know how the deck is suppose to power on all the way when you turn on your car. Some reason it isn't and I don't know why.
__________________
1990 Honda Accord EX 4 Door Sedan 2.2 Liter Engine
It sounds like your acc. wire (red) is not getting power...maybe a fuse on the car end or a connection broke loose...the deck will still receive power full time through the constant (yellow) wire and allow the CD to eject
I don't think my wires are bad because it does the same thing to the stock radio. Is there a fuse for the ACC under the hood or under the steering wheel?
Is there a fuse for the ACC? I don't think it's mis wired because the stock deck does the same thing to.
Every car I have worked on has a ACC fuse either under the dash or under the hood.
Does your cigarette lighter work? I've seen them both on the same circuit several times.
chiaxi2002
chiaxi2002
Wisconsin
chiaxi2002
BP1Fanatic
BP1Fanatic
