Car Audio System
The Kicker that I posted its says $999, but I made an offer for 600 and the accepted it...which one would you choose. please help me out. I want to make the best decision
both of those **** horribly //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Do yourself a favor. Wait 2-3 weeks, gathering as much info as you can so you can make an informed decision. Those Kickers you offered $600 for can EASILY be topped for less than $400.
If both **** then what do you recommend?
If you really got the cash I would sugest two Mag v4 12" subs and two Sundown Audio SAE-1000D Amps to power the Mags. You can build yourself a good sealed enclosure out of MDF which you should be able to pick up at a local hardware store. MDF is real easy to work with so it should make the build go pretty smooth. Pluss each Mag only needs a 1 cubic foot enclosure which will save you some room in your Altimas trunk. As far as wiring it, DO NOT BUY THE WIRE FROM A BEST BUY...... you will get ripped off. You can get it from ebay for a portion of what best buy charges. Make sure you have a decent fuse protector too, wouldnt want your money going to waste.
Thanks for the info and the link, I will look into those mags.
Now could you tell me a little about what I would have to do to the electric systems as far as if I need another battery, a more powerful alternator etc
Eric Noa
Eric Noa
Cape Cora, FL
ExplicitUrSelf
