Southeast Region Car audio shows/competitions in TN
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
  • 4
June 24th , Murfreesboro,TN - MECA 2x
July 14th , Clarksville, TN - MECA 2x
July 15th , Lebanon , TN - The Vinny MECA 3x
These are the ones off the top of my head - http://www.mecacaraudio.com
MECA meters @ the Headrest with any combo of doors and windows open in SPL, they also do park and pound which is metered 6' outside on a 30sec avg. on music , and do a very good job with SQL as well, all the shows I listed have a show and shine with them as well, and I should be at all 3 of them.
Check the website under events and click on the event and it will give you addresses and such
June 24th , Murfreesboro,TN - MECA 2xJuly 14th , Clarksville, TN - MECA 2x
Thank you for the info. Gonna check those out.
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
283
16
716
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
442
Fergg
Fergg
Nashville, TN
SplAffair
pfft
    May 1, 2024
pfft
    May 1, 2024
