caps on lights
connecting it close to the headlights? no...connecting it to the audio system MAY fix the issue...might be best to install a larger under the hood battery and maybe consider doing the BIG 3 first...
please don't tell me to upgrade the main power supply batts,alts and cables.
that's not the question.
well then you might not get too much help...as those are things that generally cause the dimming issue...and the only way to correct them is to upgrade them...
I would recommend you to upgrade the main power supply batts,alts and cables.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Maybe if you used a diode to force the current to discharge in the light, you might be able to.
ok i will set the question in other words.
is it more efficient for reducing dimming if you put the cap close to lights or close to amps or there isn't any difference at all?
he said no to the question about the headlights then he ... went in to telling him about what he could do
luv2bass
luv2bass
LA
Decipha
