Capacitors
BCONNELLY
SQ Budda
Thought I needed a capacitor for years, finally got one, but then started reading low voltage. Found out the ground wire was loose.
After fixing the problem I turned my system on, but the cap's voltage was low. I know your supposed to charge, and uncharge these things, before and after installations, but I'm not sure exactly what to do.
Caps sortta scare me with all the electricity stored in them.
I've recently been on a kick of blowing-up everything I hook-up.
An Eclipse 8104 sub, an Eclipse 9102DVC Titanium sub, and bought a Cadence 7000+HC(online), which never worked to begin with.
It's not that I've been installing my sh-t wrong, I've just had a problem with my volume knob, I keep turning it up too much!!!
Well, anyhow finally got a nice set-up with my 2 perfect 12" infinitys and Diamond D5.
So, anyhow, I by-passed my capacitor, due to my streak of bad luck, I figured I blow my sh-t up if I keept messing with it.
I'll have to say, I don't know if it really made much difference.
Why use a cap?
*sigh...*
A cap is used to improve bass response, filling in the gap between the time you have a voltage drop and when the alternator kicks in to compensate. That's ALL it was designed to do. It is designed to work with an already adequate charging system.
Instead, hit the big 3, and run larger wire. If your equipment is kicking off, it could be drawing too much power. You're not one of those people who thinks running 6 or 8 guage from the battery to the back is enough for a 600 watt amp, are you?
Does summing it up nicely include the "Oh here we go again" sigh or not? =p The similar threads feature works incredibly well on this subject.
cap //content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
big three/massive alternator //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
BCONNELLY
SQ Budda
BCONNELLY
RALEIGH, NC
bhsswrstlr
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
