capacitor keeps draining
Put it too sleep wit the fishes IF you can't get your money back for it first? if i've learned nothing else on here it's that caps or WORTHLESS in every way possible....but a small kinetik 600 or somethimg similar-big 3- lower guage wiring,better rca's anything besides the "cap"
first of all **** all the *****es that came back with negative replies. it was a simple question that required a simple answer. i bet if we was in the streets u wouldnt be talking reckless like that so shut the **** up. it is wired up right so thats not the reason why it keeps draining. thanks to the ones who had a positive reply. i am going to get rid of the cap and just go with a better battery.
Uh oh.
WATCH OUT GUYS WE HAVE A HARD CORE E-THUG HERE!
If it's wired right and it's "leaking" it would be draining your battery as well. It isn't wired right.
And no I wouldn't tell you that "out on the street" for the simple reason that I wouldn't talk to you on the street or probably be in your part of town...
^^^^^if the cap drains and is hooked up correct, then the battery would be dead every time the cap goes dead. they should be connected together:fyi:
It sounds like he was charging it and letting it sit without having it hooked up to the vehicle... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
memphisman and haunz you both are idiots.
all caps are bad, for powering anything
Thanks for setting us strait with your expert knowledge...
I guess now I'll disregard all the real world test results I've seen from Richard Clark and David Navone... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
That is how I read it as well.
keithb0223
keithb0223
Baltimore
fwb_1234
