capacitor help
Medinal7
this capacitor worked before fine and then i putit in my car and it wont work. someone tell me if this wiring is right. 12 volt from battery. grounded to chassis. then 12v from cpacitor to amp. amp grounded to chassis. none of the lights come on. please help
I had a 1.5 farad capacitor that came with my car and the only thing I could tell it did was give me a cool blue volt meter. I pulled it out and couldn't tell any difference.
should i just do away wwith it and getter a better alt. or battery? i mean i am running two l7's off a 1500 watt amp
Pretty much the best choice...then if youre seeing voltage issues follow the steps to voltage success //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
(stopping and testing between each one to see if voltage is stable)
-Big-3/Upgrade all wiring
-Add battery to rear (with a good 1/0 cable, fused on both ends)
-Upgrade alternator+Upgrade front battery
-Modify to run multiple alternators //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
-Upgrade to multiple runs of power and also ground-runs coming back to the front instead of grounding through the chassis //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Last 2 are nice, but usually not needed //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
if the cap isnt working and u exchanged it from another vehicle then it was more then likely due to not properly discharging the cap before taking it out which ultimately kills it. a alternator for ure setup isnt need i run two 12'' l7's and two 1000.1 amps and have no voltage issues. i added a kinetik hc600 battery to help cus i run 3 amps. the kinetik hc600 will help alot and its pretty **** cheap:)
Medinal7
Medinal7
Springs, TX
anj46907
