Capacitor help please
clean97A4
ive got a 2 farad capacitor and ive lost the resistor i need to charge it to hook it up.
what size of resistor do i need to charge it. and will a cap help voltage drops a lot?
ive only got one 12" kicker cvr and an alpine 400 watt amp but i have some bad!!!!! voltage drops
sounds like a real low ohm load and the amp cant take change your impedance and see if it helps before you add the cap if it helped then add the cap and you will be rock solid
its wired at 2 ohms now but on certain lows i drop from 15v to about 12v or just above.
i had it at 1 ohm but my amp isnt 1 ohm stable from what ive learned because it will go into protection mode.
so a light are you meaning like a little l.e.d?
clean97A4
clean97A4
boise, Idaho
clean97A4
