Yeah, basically. Your amp's power supply is supposed to have the caps built into it. It apparently doesn't. So you're wearing an extension. Strap another one on the end, you still won't feel anything. Get a real amp or at least real wiring. It feels better, trust me.Can I use my cap as a distro? Have the power line coming in and then 2 lines going out to my amps? It's basically the same thing right?
Shut the **** up you *******. I'll do whatever the hell I feel like with my systemYeah, basically. Your amp's power supply is supposed to have the caps built into it. It apparently doesn't. So you're wearing an extension. Strap another one on the end, you still won't feel anything. Get a real amp or at least real wiring. It feels better, trust me.
Well if you do whatever the **** you want, then asking for advice is pretty redundant when you're just going to turn it down.Shut the **** up you *******. I'll do whatever the hell I feel like with my system
I'm not asking for advice on whether or not I should use a cap I'm asking for advice on whether or not it can also be used in place of a distro block. I'm using a cap because I want the voltmeter thats on it. Not because I'm trying to fix dimming or any of that crap.Well if you do whatever the **** you want, then asking for advice is pretty redundant when you're just going to turn it down.
Better wiring + battery is a way better solution than is a cap. In all senses, a capacitor is a Spiderman Band-Aid for a gunshot wound.
To answer your original question though... Yes, you can use it as a distro-block if you can fit multiple wires into the out-port on the cap. But I would advise against using a capacitor in general. It's not doing anything bad, but it's not doing much good either.
Don't think I can.Then take the volt meter off.
Don't think I can.
A bit testicle aren't we? The Neon is surely a chick magnet. You be a bad mofo.Shut the **** up you *******. I'll do whatever the hell I feel like with my system
Nah, he's just a troll. Get over yourself.Alright I'll check into those things. I really don't care about looks or anything. I just got this for free so I might as well use it.
And I've got better things to do than e-beef. I've actually got a life.
