Silvercoupex
I have Polk Audio Momo Coaxials 6.5 in the rear hooked up to a JL 300/4. After messing with the head unit controls and the amp controls I can barely get any sound out of them. While sitting in the rear you cant even tell they are on. I can turn the sensitivity up on the amp to get more power running to them but then the 'orange/yellow' light starts flickering which I believe is the protection from clipping. So Im stuck with absolutly no rear fill....Also, If I turn the rears to the higher hz I can turn up the sensitivity up more but the lower I turn the hz to get some mid bass, the less and less I can turn the amp up...Im really pissed off I cant figure the rears out as I got everything else done. Im almost ready to cut the crossovers out and run the speakers directly to the amp.
