Can't find the remote wire for Amp on this stupid BOSE!
danfortner
Ok, So I had a little problem with the way I had my amp wired before, and now I am re-wiring it. Actually, all that was wrong was the remote wire, I had it hooked to the power to radio (in the fusebox) and it worked for 4 months like that. But then it started blowing fuses there and I removed the wire and it stopped, so I have to find some other place to connect the remote wire to.
So I pulled out the console on my RL and connect it to what is called the "Radio Remote Switch" and that actually partially turns on my amp. It just turns on a light which indicates that there is power, but it does not turn the amp on once the radio/source starts sending it signals! I also tried the Acc wire, but that does nothing.
So I am wondering, which wire you guys would think I should use for turning on my amp via remote turn on wire. Here are the places I have to choose from (Look at the 99 WITHOUT navigation part):
behind the HU/console
behind the acura-bose amplifier, which is located elsewhere
attachment.php
PLEASE HELP
THANKS
Yeah thanks: FIXED
I used the stereo amplifier power wire. (A6)
The nice thing is that now the system does not turn on unless the car is running. (It will not turn on at Accessory II key position.) Well its just good to have if fixed again, although lets see how long it lasts, hehe.
danfortner
danfortner
Mystic, CT
danfortner
