Cannot Decide
Which one running little less then 1000watts
  • Q
    Votes: 4 44.4%
  • SSD
    Votes: 5 55.6%
  • Total voters
    9
solidcrowd
Alright here it is:
Fi Q
Fi SSD
The only reason im asking is because i heard that the q likes alot more then 1000watts and im getting the alpine mrd-m1005. Also, the q is a sq subwoofer and the ssd is more spl but im wondering if the ssd even though its on the spl side would it still sound better than the pioneer ts-w3004spl.
Alright now im leaning towards the ssd when i was just about to order the q.
I was wondering if you guys could point out the pros n cons of the ssd over the q.
Price isnt really an issue thats y is such a tough desicion.
1. ssd more output?
2. big difference in sq from the q?
Also, would the ssd out perform the q if i added BP power and copper coil?
I have the specs on both and was wondering the pros and cons the ssd has over the q.
FI Q
Fs: 28.4 Hz | 27.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 05.39 | 5.63
Qes: .49 | .48
Qts: .45 | .44
Cms: 0.15mm/N | 0.15mm/N
Sd: 481cm^2 | 481cm^2
Vas: 48.3 l | 48.3 l
Spl: 85.4dB 1W/1m | 84.8dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
SSD
Fs: 27.0 Hz | 26.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.60 | 4.71
Qes: .52 | .49
Qts: .47 | .44
Cms: 0.18mm/N | 0.18mm/N
Sd: 480cm^2 | 480cm^2
Vas: 58.7 l | 58.7 l
Spl: 85.3dB 1W/1m | 85.3dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
solidcrowd
solidcrowd
Buffalo, New York
AndonD454
