Can someone help me with Aero port lengths?
Ok from what i understand, there is many way of getting the same tuning with different port and lenght. But you still have to have a minimum port sq. so if my box is 8ft/cu with an Fi Q 18 with 27mm of xmax and a tuning of 32hz, i'll need 12,99 minimum diameter and minimum 132,53 inch/cu of aeroport.
Then, if i put everything in the good case with 6 inch aeros, i'll need them to be 14,21 lenght. so. so Pi x Radius 2 for the port area = (3,14 x 9 x 14,21 ) x 2 = 803,15 inch /cu of port??? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
ok just came back from homedepot. They got 3 inch x 6 feet and 4 inch x 6 feet (i think it's external dimension)
the box is gonna be those dimension : 37.25 width x 21 height x 22 deep for a total of 8.3 before all displacement. The port are gonna be on the from left to right / right to left of the box and sub facing top ( no other possibility , that's the only way i got 6 inch clearance in front of port). Is it possible to do something with the 4 inch port? pm me a working design and you'll get a small paypal donation //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'll be using 3/4 mdf, 32hz is the wanted tuning ( minus possible) on a fi Q 18.
thank you i'll be waiting for pms from good designer. And no i can't find anything bigger //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif The aeros will just be lenghty ( 37,25 - 1.5 mdf - clearance) will be the max lenght
lil bump for a lost guy //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
4 aeros of 4 inch with a lenght of 13 inch each for 32hz tuning in 8.3 ft/cu ??? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
lil bump //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif if i ain't getting anwered i'll need to do a another thread, which is annoying to everyone //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so whats and easy way to figure out how much port are u need when using areports? Im building a box thats 4 cuft for 1-15" i was thinking about going with 2 6" aeroports but thats seems like a lot now.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
528hz
Everything'sMiscellaneous
528hz
In the Space between Space in NM
spl_robb
    May 16, 2024
    May 16, 2024
