standard 10+ year member
I was wondering if I could bridge my two 4 ohm subs on a 2ohm stable legacy 1600 or will that be too much for it to handle; for anyone who has one and has tried it?
This is a LEGACY AMP! I've never seen a 2ohm [mono] stable legacy amp cause that would equate to a 1ohm stereo stable AMP. I'm not sure if you understand the fact the when in mono/bridged each channel shares the load. This is why you see 2ohm[stereo] stable AMPs that can only take 4ohms bridged. As you know 4ohms shared by 2 channel would give each channel a 2ohm load. They share the load cause when a AMP is bridged 1 channel pushes while the other pulls.Originally posted by taylor is this 2 ohm mono or stereo stable!!!! if it's mono then you can bridge your 4 ohm svc subs off of it, that would be a 2 ohm load!!!
I'm not talking about a wiring config. i'm talking about what the AMP would see. If you were to parrallel 2 SVC 4ohm subs that would be 2ohms--correct! BUT if that load were placed on a BRIDGED amp that AMP would have to be 1ohm stereo stable[2ohm mono] which legacy isn'tand chris how does an amp being one ohm stable get into the equation, you only get a 1 ohm load from two subs wired in paralell with 2 ohm coils.
