Can I wire my box in parallel??
yes.
If you're asking how, it's simple.
Connect all the negative leads to the negative terminal and all of the positives to the positive terminal. You only really need one speaker terminal on the box for this setup , unless the subs are in separate chambers.
If that's the case, then wire each subs two negative wires to their respective terminal cup's negative spot. Then wire both positive leads to the cup's positive post.
On the exterior of the box take the two negatives and put them in the amp's negative hole and the positives in the positive hole.
93 saturn sl2
93 saturn sl2
Michigan
fwb_1234
BP1Fanatic
BP1Fanatic
