Can I put these?
Polar
Im my only 3 cube ported box, run the amp at 4 ohms, 600 rms for break in until I can get around to making the 5 cuber for them?
When people complain about too small of a box it's mainly an issue that it's not ideal for that driver and the FR isn't desirable in most cases. Don't be surprised when you switch enclosures if it sounds completely different. It may sound like crap depending on what your box is tuned at as well as if thats 3 cubes before port and sub displacement are figured in.
For two that is way to small. You can do it in a small enclosure, but you will have to mount them inverted to get more airspace.
Then wire them up at 1 ohm and turn the gain down if you feel you need to break them in.
Polar
Polar
WPB, Florida
Polar
