I'm sort of a noob, and I really need help. I have been blowing speakers the past 6 or so years (about 1 speaker every 2 years), I think from underpowering them. I am bad with ohms but each speaker is running off of one terminal so I think its at 4 ohms. If the rear speakers need 110, and the fronts need 55, what do I do as far as power? Because I can't direct an amount of power to each speaker as I see fit. Do I keep my amp or get a new one? Or for the same price get a different set of speakers for the front or something? Help me out...
My amp is: MTX Thunder4320
• 40 watts x 4 into a 4 OHM load with less than .1% THD.
• 80 watts x 4 into a 2 OHM load with less than .3% THD.
• 160 Watts bridged x 2 into a 4 Ohm load with less than .3% THD.
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC:
• 85 watts x 4 into a 4 Oh load.
• 140 Watts x 4 into a 2 Ohm lead.
• 280 watts bridged x 2 into a 4 Ohm load.
Front speakers are: Infinity Kappa 52.5i (5 1/4 in)
Power Handling, RMS 55 Watts
Power Handling, Peak 165 Watts
Sensitivity 94dB
Frequency Response 55Hz - 25kHz
Mounting Depth 2-1/16"
Impedance 2 Ohms
Rear speakers are: Infinity Kappa 693.5i (6x9)
Power Handling, RMS 110 Watts
Power Handling, Peak 330 Watts
Sensitivity 95dB
Frequency Response 35Hz - 25kHz
Mounting Depth 3-3/16"
Impedance 2 Ohms
Sensitivity 94dB
Impedance 2 Ohms
Sensitivity 95dB
Impedance 2 Ohms
