can i get some help please
  • 2
jlaudioman
Hey guys, I have a quick question here.......I am having a problem with a battery that keeps going dead. I have a pioneer diskchanger hooked up and i think that is what's causing the problem. The battery goes dead when the car sits (parked and turned off) when I'm home for more than 8 hours. Could the remote wire and the memory accessory wire be wired backwards causing the drain? Or the other thing that I think it could be is the battery post terminal......when I charged that battery the last time and was hooking it back up, I noticed that as I was tightening the positive terminal, the light underneath the hood would go off and on. Could the battery dying also be from a bad connection with the battery post? The post is the kind where you screw the terminal in and the put the power ring around another post and then screw that one in on top of the first post. Any advice is greatly appreciated. Thanks.
jlaudioman
sounds like something is wired wrong and not shutting off....i'd try re checking all the wiring and see if there is anything else that might be causeing a constant drain....good luck
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
953
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
jlaudioman
jlaudioman
Columbus, OH
MikeofTulsa
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
