Can I do this...
Fusion_FREAK
Story of My Life...
I hve a Kenwood KAC-729s amp.
Here's the specs I pulled off Crutchfield;
stereo or bridged mono output
Tri-way capable (Tri-Way Crossover required)
300 watts x 1 in bridged mode
150 watts x 2 at 2 ohms
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
80 Hz selectable low-pass crossover, 18 dB/octave
speaker-level inputs
4-way protection circuitry
signal-to-noise ratio 100 dB
I have a Mach5 MAW 15 sub, and as of now, no sub amp.
The MAW is wired at 2 ohms. Can I hook up the MAW to my amp, in bridged mode at 2 ohms?
nope......that amp is only stable at 4 ohms or higher in bridged config
I'm assuming that sub is a dual 4 ohm, and if it is you can wire it in series to get 8 ohms which will be safe on that amp, you will just get less power from the amp
Fusion_FREAK
Story of My Life...
Fusion_FREAK
in the garage
Fusion_FREAK
