Can I do this???
GTSLVR4
My setup is ::
Subs :
3 JL audio w3v2's
400.1 kicker ZX amp
750.1 Kicker ZX amp
Speakers :
Polk audio 5 1/4's front + rear speakers
200.4 Kicker ZX amp
What I wanted to do was add in these tweeters :
http://cgi.ebay.com/LOT-OF-2-PAIRS-INSIGNIA-TWEETERS-200W-1-NIOBIUM-DOME_W0QQitemZ300195525687QQihZ020QQcategoryZ58036QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Would these be okay to add in or will they crackle/distort or cause any problems to the system, seeing that it is a pretty high power system.
Also, if I did add these in I would splice the front tweeters into the front speakers and the rear tweeters into the rear speakers right?? Also, if I did that would the tweeters also be powered by the amp and wouldnt be a problem?? Or will I need to buy a seperate amp to power the tweeters?? I'm a little confused. If someone could help me 'd appreciate it. Thanks!
Okay, So I can power them from the same amp. Will I need to get a more powerful amp to put out more power since im now splitting the wattage between 8 speakers instead of 4??
Also, how exactly does a passive crossover work?? I just install it and thats it?
I just put the speaker wires to ''in'' then put the wires for the speakers to ''Mid'' and the tweeter speaker wires to ''TW'' ?? And thats it??
http://cgi.ebay.com/New-HiFonic-XT-1-X-Over-2-Way-Passive-Crossover-Audio_W0QQitemZ150213459269QQihZ005QQcategoryZ79840QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
Will putting in this crossover keep the tweeters from crackling?? ATM I have 2 tweeters hooked up and when I turn the volume up loud they crackle hardcore and sound TERRIBLE. Will this fix the problem?
Sounds good. I appreciate it guys. 2 last questions and thats it! I promise! =)
Will I need 2 sets of them because I have 2 pairs of tweeters? (2 upfront and 2 rear)
Anyone have an answer to this? I'm kinda stuck..
yes, to properly play at a passive crossover's crossover point, you will need ONE crossover for EACH set (1 mid, 1 high) of speakers. If you wire more than the set amount of speakers to a passive, you change the ohm output, and that DOES have an effect on the crossover point.
GTSLVR4
GTSLVR4
Poughkeepsie, NY
Ken448
