Can I do this?
Yes.
The only difference is that on Alpine you enter it as a millisecond delay while on Pioneers you actually enter the physical distance.
So basically with the Alpine there is more math involved on my part? Figuring the time correction figures based on the distance?
Some of us do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
true... but there are not many. espically on here //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Not sure if this amp has two sets of RCA inputs, but wouldn't it need to in order to run comps and sub? I mean, I don't want to run the sub off a "full" input do I?
I've got the Alpine 9833. It's been awhile since I've had it in one of my vehicles, but I believe it has a LP and HP crossover built in. If not, the amp has two crossovers so I should be good.
The 9833 is a nice unit. Yeah it has HP and LP. Use them. Much easier to adjust and will allow you to use the time alignment features as well as sub level control. Run 2 sets of RCAs, front outputs to the ch1/2 inputs on the amp and sub outputs to ch 3/4 on the amp. Set the crossovers on the HU. Set the amp outputs to full range. Bridge the rear channels for the sub. Good to go.
AllstarE4
AllstarE4
DFW, TX
helotaxi
