Can anyone identify this Memphis sub?
Ridinhi
Just picked it up local for $10.00. Sub is in great shape for its age. 15" single 4ohm is all I know. Im thinkn its from the era when Memphis was Fultron. Anyways, what I would like to know is what size ported enclosure should I build for it. Wanna go as big as possible to get the most low end. Also, im sure it will not need much power at all. Going in my suburban to fill in the low end. I know i wont be gettin loud with this sub,just want to build a box thats would maximize effeciency. Not even sure whats it rated power wise. Any help would be appreciated.
They still sell those same subs at a store around here, if I'm not mistaken it'sa 4 ohm Dual Voice Coil sub, and I thinks it maybe be rated around 700 watts.
You are correct on the 4ohm part but I personally dont think that this thing is rated at 700watts. And thats single 4ohm coil at that.
Seriously though OP, if you don't have an amp for it, you can probably find some 2 channel on craigslist for $20-40 that'll do the job.
thats what imma do, find a 2 channel thats around 250-300watts bridged and try it out in 2.5-3 cubes sealed first,then may go for the 3.5@32hz as you suggested.
Ridinhi
Ridinhi
Winston-Salem, NC
Ridinhi
Mike Mccabe
