Can 10w7 handle 1000 watts?
It can handle it, i have a mtx 1501d on mine (3 ohm load = 1000W rms at 14.4 volts) I asked the guys at the shop i bought mine from if they thought it could handle it and they said it will take 1000W easily. Just watch the gains on your amp.
I have read the power chart! I also know that JL amps are usually more powerfull than stated so I did not know if there subs would handle more than rated?
I am lookin to run 3 10w7's and 3 1000/1's for a spl set up. just trying to research first.
So I guess the answer is NO?
No one has ran a 1000/1 to a 10w7.
I have read the power chart! I also know that JL amps are usually more powerfull than stated so I did not know if there subs would handle more than rated?I am lookin to run 3 10w7's and 3 1000/1's for a spl set up. just trying to research first.
I would not run twice a drivers RMS to it in hopes of more output, when you could simply get a driver that can handle the power and get equivalent output. Three 10w7's is a pretty penny, why not go for two 13w7's and two 1000/1's? Should cost a bit less, and you will be able to safely run the power you want.
Or go for another manufacturer entirely....
it isn't the power that i want to run. i believe that 2 13's is stock 3 and 3 10's is stock 2.
I was acually thinking about 3 10w7's and 3 500/1's but was told it probly wouldnt compete well in stock 2.
maybe i'll do 3 500/1's first if it doesn't produce like I want then I'll do 3 1000/1's
I thought that as well and was gonna run w6v2's but I have heard so much about w7's. I have a friend with 1 10w7 on 1 500/1 turned down and it hits nice! so I can only imagine 3 10w7's on 3 500/1's or even 3 1000/1's in my hatchback!
P52ENVY
P52ENVY
TAMPA, FL.
P52ENVY
