Cadence ZRS-8000D pair for sale new and used
art1618
for sale are two 8000ds the two on the boxes are the good ones, the other two need repair. I WILL NOT SEPARATE THE PAIRS. i need the cash to repair the busted ones and sell those too.
one is new in open box, other has few hours on it. i only have one bass 'mote and i have the link wires for them.the boxes are kinda messed up from moving apts so much. tired or dealing with CL dbags. i have a 250 amp alt that drops in a 05 scion xb and same motors. i sent it to MM and it got repaired and was not installed since. dont know if it works honestly. if enough interest ill correct post. 8 rib pulley, has a bracket and harness for a 02 ram.
TRY ignore my rediculous laugh.
sub wasnt in a box so obviously didnt take much power to mess it up. the amps used there are the ones that are busted now.
SPECIFICATIONS:
4 Ohm RMS Power: 1 x 800 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 1400 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 2000 Watts @ 13.8 Volts
IHF-2002 Peak Power: 1 x 4500 Watts Max @ 1 ohm
Two Z8000D bridged together = 1 x 4500 Watts Max @ 2 ohm
Frequency Response: 10Hz - 400Hz
S/N Ratio: >100 db
Damping Factor: 230 @ 100Hz
Minimum THD:
Input Voltage: 200 mV - 8 Volts
Dimensions: 17.8" x 9.4" x 2.4"
FEATURES:
High Speed Mosfet Power Supply
Bi-Polar Japanese Sanken Output Devices
Copper Rail PCB Architecture
24 dB Crossover Circuitry
Fully Adjustable Low Pass Crossover
Low Pass Crossover: 50Hz - 150Hz
Bass Boost Equalization: 0-18db @ 45Hz
Subsonic Filter: 15Hz - 40Hz
Lucite Encapsulated Large 4 Gauge Terminals
Soft Start Mute & Delay
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
RCA Line-In/Line-Out Jacks
Includes Dash Board Bass Remote
$800 for both or $1k for all 4. hope price is reasonable. the amps are too costly for me to repair. im broke. amps are 16V capable. if you fix em its 9kw of power for a grand. i just dont have the moneys anymore.
i typically use UPS. choose. ships from 79938
View attachment 26527342View attachment 26527341View attachment 26527343
art1618
art1618
el paso tx
art1618
