hey I've got a txa-1000d and it says it has an output of 1000 @ 1ohm @ 13.8v
My jeep alty puts out 14.4v so will this effect it? so will the amp be drawing 14.4 v from the alty and thus have a higher output than 1000watts? Also does anybody know what the true output of this amp is? i heard it was 1300 watts @ 1 ohm.Thanks for help!
* 4 Ohm RMS Power: 1 x 350 Watts @ 13.8 Volts
* 2 Ohm RMS Power: 1 x 650 Watts @ 13.8 Volts
* 1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
* 2 Amps Bridged 2 Ohm RMS Power: 2000 Watts
* Frequency Response: 20Hz - 500Hz
* Damping Factor: >500 @ 100Hz
* S/N Ratio: >100 db
* Minimum THD:
* Dimensions: 25" x 9.2" x 2.12"
* Minimum THD:
