cadence or keenwood,which would you buy.
Cadence SQA-1 or Kenwood 9104D
kenwood specs....• 1800 Watts Maximum Output Power with 30% Smaller Chassis Size
• 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
• 1-ohm stable (output regulated to 900 Watts)
• Variable low-pass filter (50-200 Hz at -24 dB per octave)
• Bass Boost Control (0-18 dB at 40 Hz)
• Subsonic filter (15/25 Hz, 18 dB/octave)
• Class D design
• Speaker-level inputs with signal sensing turn-on
• Preamp-level inputs and outputs
• Fuse rating: 30A x 2
• 13-11/16"W x 2-3/8"H x 9-5/16"D
cadence...4 Ohm RMS Power: 1 x 500 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 700 Watts @ 13.8 Volts
Frequency Response: 20Hz - 300Hz
S/N Ratio: >100 db
Damping Factor: >200 @ 100Hz
Minimum THD:
I had a friend with that kenwood amp and its not really 1 ohm stable. When swapped for a 500/1 the 500/1 killed it but couldve been from voltage drop? The internals are tiny. I repaired a blown trace on it after he overheated it.
My first amp was a kenwood 1700 watt. I learned on it and abused it. Still abusing it now and again. It's covered in wire and screw driver arcing scars. Full blast for tones till it protected over and over. And it can get a sub wangin'.
I think amps are like cars. There are good ones and bad ones in the same make and model.
pickup1
pickup1
Polk City Fl
alvitae
