cactus pf600.1
ok the first 2 hits the voltage was to high, and had to bleed some off before it was able to go to a full roll.(kept clipping out).
.22 ohms
17.7v
2v of input
18 powermaster batts.
dc amperage i have no clue
my meter is always 1db off that was me out of it totally add 1db for me in the drivers seat also
you see it at about the 5-6 hit after the 4th i ran the alternator to charge the batts up and they were sitting to high thats why i had to bleed voltage off so it would not clip out on me.
the first hit was 158.8
sensor is in the kick
Please do a test after 3 seconds and see where the meters are at. Not peak hold.
Sure it may help you keep track of gains in power but it doesn't even come close to real power output.
ok audio ima put something in perspective to you. These are the amps I have used in the last 5 years that I have been competing all tested the same way with my results.
ddz2=11,900 watts
rd audio 9.0=9800 watts
ia40.1=8800 watts
ab 500.1=8900 watts
ab 200.1=6600 watts
treo 4.1=7200 watts
ab xd3000=5600 watts
ab 400.1=6900 watts
mmats 3000.05=4200 watts
catus pf600.1=8400 watts
ddz1=6200 watts
ddm3=4600 watts
as you can see I have tested alot of amps some big some small, and for the 600.1 being able to keep up with the 40.1/500.1/400.1 its a testimate to the cactus. No matter how you look at it if I use peak hold its a referance to see if whats im doing gaind power on the output, and 4 world titles in 6 year after the first of january I am doing something right, and im not changing anything just because you dont like it.
z2 is the strongest amp I have ever tested
oh and fuse I dont run fuses fuses in usaci will get you beat when they pop lol. Its direct wire from batts to amp
Next time you play with it,think you could swith your clamp to DC and see what this amp is drawing? Wouldn't be hard.
sanman
sanman
JUNCTION CITY KANSAS
Jeremiah25
    May 12, 2024
Brendon Jenness
    May 11, 2024
