c-Pillar wall
I'm in the same boat as you actually. I'll be watching.
Is there anything specifically you're looking for?
Just if it's worth the effort. As it stands, my output seems primarily limited by box size and also acoustics. For example, pretty much anything I stuff into 6-8 cube net is about the same on the meter, but as I try to go larger to accommodate more subs I wind up with issues the port too close to a wall somewhere so I hit a limit on gains there as well. Overall, I can get better numbers with 4-5 cube net with the ability to angle the sub/port placement vs 10 cube with double the cone area with sub-optimum port placement and subs sitting too high.
Hoping someone will chime in with some real world experience or links to some build logs of some that have worked well.
hispls
hispls
Central Maine
hispls
