bxi2607d vs opti2000d
Amplifier - Import Tuner Magazine
TEST RESULTS
OUTPUT POWER @ 1%THD, 1KHZ, 14.4VOLTS
MONO @ 4OHMS 770 WATTS
MONO @ 2OHMS 1118 WATTS
MONO @ 1OHM 1687 WATTS
MONO @ 0.5OHM 1962 WATTS
OUTPUT POWER @ 1%THD, 1KHZ, 12.5VOLTS
MONO @ 4OHMS 673 WATTS
MONO @ 2OHMS 988 WATTS
MONO @ 1OHM 1406 WATTS
MONO @ 0.5OHM 1635 WATTS
DISTORTION AT RATED POWER, 1KHZ, 14.4VOLTS 0.14% @ IMPEDANCE
INPUT SENSITIVITY 250MV TO 8VOLTS
FREQUENCY RESPONSE ( + 1DB) 15HZ -130KHZ
S/N RATIO (A WEIGHTED, BELOW CLIPPING, MIN GAIN) > 83DB
SLEW RATE 6.5V/MSEC
DAMPING FACTOR @ 100HZ, 4 OHMS 105
IDLE CURRENT 2.1AMPS
MAXIMUM CURRENT CONSUMPTION, UNCLIPPED 117AMPS @ 1152WATTS
EFFICIENCY AT 1/3RD POWER LOWEST IMPEDANCE 79%
EFFICIENCY AT FULL POWER, 1%THD, LOWEST IMPEDANCE 85%
CROSSOVER SLOPE 24DB/OCTAVE
CROSSOVER RANGE, LOWPASS 48HZ - 155HZ
SUBSONIC SLOPE 24DB/OCTAVE
SUBSONIC RANGE, LOWPASS 14HZ - 56HZ
LOW FREQUENCY BOOST +19DB @ 43HZ
DIMENSIONS 19 1/8"L X 10"W X 2.5"H
TEST RESULTS
SLEW RATE 6.5V/MSEC
well glad to see it does rated
kinda shy from 2k
kinda shy from 2k
You going to notice the 38w?
no. texican said it did rated. i just show him from the test it did not. that is all.
you 2 should learn to read before posting
if its puttin out 1962 watts at .5 ohms, I really doubt it if you gonna know that its not doin the extra 38 watts
Actually the last RMS rating Lanzar provides is 1600 at 1, which it meets.
Their only claim is that it's stable at 1/2 ohm because we should all know enough to recognize the 2000w MAX rating really has no meaning at all.
It happens to do more than 1900w with unusually high efficiency.
Actually the last RMS rating Lanzar provides is 1600 at 1, which it meets.Their only claim is that it's stable at 1/2 ohm because we should all know enough to recognize the 2000w MAX rating really has no meaning at all.
did they like discontinue the opti2000d because mostly every place i tried to order one keeps telling me they are out of stock of the opti2000d
texicanz
texicanz
moline,il
texicanz
vegang
vegang
