timma100
Thanks to TheUnderFighter il be picking up a SAZ-1500D in the next week or two. This amp will be powering two Earthquake DBX12's. The DBX12's are dual 4ohm rated at 400W rms each. I can do math and I know sundown amps are underrated so if I screw up i'm VERY likely to blow my subs. So my questions are as follows, (and yes I know I should google each one and read up, but between college and work I don't have copious amounts of free time.)
Edit: wanted to add another question, my current amp (Xplod XM-GTX1852) is wired to mono 4ohm, witch has an RMS rating of 400W. The SAZ-1500D also has an RMS rating of 400W @ 4ohm, but I assume there will be a difference. Am I correct?
Gain, I assume its directly related to sub power.
Subsonic, no clue, some type of LPF?
LPF, frequency cut off for amp response, right?
Bass Boost, kinda obvious, but should I use it? I assume no
Phase, No idea
If you can give me tips on ANY thing I mentioned or just general info I would really appreciate it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I don't feel like destroying my things :|
Phase, No idea
