BTL or Nightshade
What are you running amp wise. cubic ft for box. and DB's????? Im just curious what they can do.
5.8 cubes net, tuned to 32hz. Running off a Crunch GP3000D Pro and it slams. Haven't metered it yet since I blew the amp a little while ago and am still working on fixing it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
http://www.caraudio.com/forum/showthread.php?t=439577
It's not uncommon for the NS to produce a higher score on the meter than a BTL in a direct swap based on customer feedback -- although, the BTL has a higher continuous thermal power handling than the v.1 Nightshade.
The nightshade gets louder than the btl but the btl sounds better...nightshade can be ran in 4 -5 cubes...the choice is yours grasshopper hope that info helped...
but anyway unless u buyin used u wont b gettin a brand new nightshade.also y u tryin to squeeze a 18 in a trunk?
And I talked to a guy about getting a used 18. I can fit 4 12's at 1.8 cubic ft a sub in my trunk so an 18 shouldnt be a big deal.
Thanks. 5ish cub. should fit in my trunk nicely. I'm thinking on going with the used nightshade.
I believe FI recommends a minimum of 5 cubes...
Are you saying you have 5 cubes gross for a box? Because my box is 5.8 cubes NET but closer to 7 gross...if you only have 5 gross then you don't really have room for either.
hell b better off gettin the ns since the min is 4 cubes
Are you going to face an 18 up in your trunk? Id go down to a 15 unless you're not going to fire the sub up.
thats probably his only opinion, i doubt is trunk is taller than 18in.
then he has to worry about gettin the box n the trunk first, trunk opening is too small iirc
If he only has 5 cubes gross he'd be better off just going with a 15 because after port and sub displacement he'd be under 4 net. A 15 in the proper sized enclosure would be better than an 18 in a small enclosure ya know?
Would I be better off just waiting a month or so and just getting another 2000watt sundown amp and 2 BTL 18s n just have someone help medo a wall in the back seat? rather than try to jam a 18 in the trunk?
Face of Fear
The Beard
Face of Fear
Iowa
mazdakid
