Bridging Memphis Bell
Damaso87
iPoor
Hey all, i was just finishing up the fabrication part of my install, kickpods are done, amp rack is done, it all looks clean, but as i was running the wires i started thinking...how do i bridge the 4 channels of this thing? I recall hearing about a bridging module, but i hope i dont need to use that!
Any advice would be stupendous
ive got the memphis belle 16MCH-1300
http://www.memphiscaraudio.com/support/default.asp
You don't need the bridging module for that. Just bridge the channels like any other amp.
The bridging module for that amp is for the single rca input for the sub, which you don't need for that either.
Here is the response from Memphis about this same issue, I just used a rca Y adaptor for the sub input.
You would benefit (sound quality wise) IF your current subwoofer pre-out from the head unit isn't mono (before the y adaptor).
If you are currently inputting full range signals for front and rear, disconnect channel 5's rca input to get a
preview of how it would sound with the "correct" signal. You will still get an output on channel 5 (with no input),
presuming you have inputs to channels 1-4. The amp will derive a signal for you.
Hit the nail right on the head.
Damaso87
iPoor
Damaso87
Springfield, MA
king nothing
