Brand Matching
Some people are ADAMANT about having brand-matching ish.
But, as for sound quality [or sound pressure level for some of you people ^-^], there's no real impact if you mix and match brands. Most companies do make amps to match their subs (it's only logical), but often times, the amp to match the sub, or sub to match the amp is over-priced. So, people will resort to another woofer or amp that will do the same for a less price.
unless u start getting into eqs and xovers then that's a different story.
Not really.
An EQ is an EQ regardless of the brand-- that is to say, a hypothetical JL EQ will do the same as a hypothetical Alpine EQ [Not sure if either brand makes EQs] if run off the same source. It's all the quality of the build, not if the serial numbers are similar //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
the last thing u said cept all my stuff matches but my hu and that's cus i'm a idaholic
same hear i love Id's stuff and am in process of going back got 2 pairs of those oem mids and cd2 horns just need to find Idmaxs at a good deal then im there
Not really.
when i mentioned eqs and xovers i was more thinking in the line of how some companies like Arc use din cables and etc to send the signals instead of rcas. where having both the amp and eq/xover coming from the same company would be a good thing.
shaneb
shaneb
Fort Worth, TX
Horsemanwill
