BassAddictJ
Oh man, here we go....
So I've had my amp worked on a few times by a very reputable specialist, and the problem seems to be my 0.8ohm DCR load going to my rated 1ohm amp. I have okay (not ideal, but not bad) current on tap, and the amp components that keep failing are consistent with running below rated imp. Sure there's imp rise, but that only happens after cone movement and a bit of playing. When that signal first hits it's stressing those parts that aren't rated for under 1ohm. I realize most woofers (custom or OEM) come with DCR's a bit lower than the nominal rating...but what I'm told makes sense and I want to keep my amp in it's rated stable range. This guy sees the same problems and ALLLL kinda of amps (sundowns, AB, us amps, RD's, you name it) they all pop eventually running under rated imp in time, its just a matter of when.
I have WAAAAY too much time and money put into my sub and sub amp. Changing them out for something else really something I'm trying to avoid. And I cant afford to keep fixing it every other month. So aside from beefing up mybattery bank a little, I have an atypical idea....
I'm thinking about finding a spool or wire, say 20ft or whatever of 8awg or something...something with about .2ohm resistance, and put it in series between the amp and sub. It'd have to be wire that'll handle that kind of current, and it'll need to have proper heat dissipation....I'm just wondering if anyone knows a specific reason why this would be a terrible idea? I know it's not ideal, none of this is....but if I can just get my load to the amp to sit a tad higher safely, I'll be happy....and I'm skeptical there's any dummy resistors out there that'll do the resistance AND current capability I need without being a fire hazard.
Thoughts??
Thoughts??
