Bracing with 2 X 4's???
Home depot.
You can get anywhere from 1/4" thick to 1" thick.
I use 5/8" my self. Its only like $4 for 3 feet of it. You have to get 4 nuts and 4 lock tite washers, if you are only doing 1 rod.
2 Nuts on inside, 2 on outside. Same with Washers.
Home depot.
I am not sure that I understand how you are using these things because they come precut and threaded and I would probably need a specific length.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif maybe try cutting it, lol....the lowes by me has them in ~6ft legnths. If you dont cut them right you'll have a total ***** of a time trying to get the nut on though. I use a jig saw on high speed
A regular hack saw works too.
Thats what I use.
Inhuman probably cant use it cuz hes not buff enough....
Do you want me to take pics of it for you?
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well, I guess that's the response I should expect to receive from such a vague question //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . I guess it would have been better if I had asked how you get the piping re-threaded once you cut it off??
cut it between the thread when you start, and dont try to bend/break it...basically the cleaner the cut the easier it is to thread the nut on
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
Goldtaz1
Goldtaz1
Montgomery, AL
Goldtaz1
    May 31, 2024
    May 24, 2024
