box plans finished.... three e15ks.....look right?
Musto
Alpine+eD = kick ***
heres the basic idea of my webpage, i had to get help with my geometry teacher, but i have a list of the angles and sizes all that that the peices should be cut to, it came out to 9.1 internal cubes.... is this enough for 3 e15ks? 12 would be better, but is 3ft3 each enough? still dont know how this is going to fit in my trunk...... the space is well enough, but how do i fit it into my trunk, it cant slide straight in,,,, how do i do this??
Matt
Matt
3 cubic ft per k is plenty, i dunno how u would fit it, u might could take backseat out and slide it in
watch the angles too... will the depth of the subs touch each other when it's in place?
hmm.. you should've thought about putting it in the back before building the box...
anyway, as abcdefg said, try removing the rear seats, although there are many cars that will have some sort of bar or plate there...
worst case, you've got to build a new one... if you still want the same dimensions, you could either
1. take apart the box and build part of it while it's laying in the trunk
2. build the box in the trunk from scratch.
Originally posted by paikiah watch the angles too... will the depth of the subs touch each other when it's in place?
i was thinkin about that, is it fine as long as they dont touch? what iof their an inch apart? it should be ok as long as the subs just dont tough, right?
well, I guess it wouldn't be too much of a problem, cause I've seen many demo vehicles with boxes similar to yours, that would nearly be touching each other near the magnets, but they have no problems pumping good tunes... I guess if they're TOO close, then maybe youv'e got some magnetic filed issue or something, but other than that, good box layout..//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Musto
Musto
Hattiesburg MS
avistar23
