Box, look alright?
hockey512546
This box is for a Fi SSD 12, around 2.2 @33Hz
46.5 sq" of port area and about 46.75" long
Does this look alright/ will it work? This is the first box I've designed
In particular, will the short bend in the port inside the box work out?
Arent the corners of the port gonna mess it up? You should make the port the same width all the way throughout, and those corners will make it smaller there.
you fail geometry? Those braces are in there to so that it WILL be a uniform width...
If they weren't there that area would go from 3" wide to 4.5"It isn't uniform through the whole corner though, that would require an arc at each corner
Yep, just said that in an earlier post. I dont have my thinking cap on tonight //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
hockey512546
hockey512546
Bloomington, IL
PsychoTheRapist
