Box Guru's - simple question
Torquem
Apex, NC
I am building a sealed rear firing box for a couple of Boston G5 12's. The enclosure at max can be 32 inches wide, 12 inches deep. Height is not restricted. 2 chambers. It will be constructed of 3/4 MDF. I am curious what my final dimensions will be with those parameters changed from Bostons recommended which is
Model: G512
H = Height: 10.5" (26.7cm
W = Width: 13.0" (33.1cm)
D = Depth: 13.0" (33.1cm)
Gross Volume: 1.0 Ft3 (28.3L)
Q-Tune™†: (HP & Q) 28Hz@0.707
Enclosure dimensions are internal and include basket displacement
I come up with internal diameters of
H = 13
W = 14
D = 9.5
With a double thick front I come up with external diameters of
H = 14.5
W = 30.25
D = 11.75
Am i right?
Id go a little bigger on the box try to get 1.25cuft per woofer because u are not taking into account the woofer displacement ...if u have the room i highly suggest porting the G5s in around 4cuft tuned at 32hz, i still miss the one g5 i had that was ported in a 2 cuft box tuned to 32hz
they recommend 1 cube gross.
take whatever box dimension in inches LxWxH/1728 to get cubic feet and your goal is 1.0
with sealed, you won't have to worry so much about the shape, just the volume.
157
506
811
641
Torquem
Torquem
Apex, NC
djman37
audiobaun
    May 19, 2024
    May 19, 2024
