ck.barickman
Hey guys, my Boston 12.5LF's came in today and I'm stoked. The paperwork says to build EXACTLY 1 cubic foot per woofer so that defiantely takes a lot of the guess work out of it. So I have two questions. Should I build 2 seperate fiberglass enclosures (one over each wheelwell) or build 1 MDF enclosure that would just sit flush against the backseat. I would prefer to have fiberglass enclosures because it would be less intrusive on my trunk space. Unfortunately, I've heard bad things about aiming woofers at eachother. Someone please set me straight. Also, if you recommend just an MDF enclosure, should it be a common chamber or separate chambers? I would choose seperate but there is a diagram within the paperwork that shows a shared chamber. Any input is appreciated. -Connor
This is where the woofers would go for fiberglass encloures. One on each side.
