Boost Head Unit before Dual amps.
  • 4
divco13
nsb
Factory 6 disc Head unit. Has Bass & Treble slide adjustment. It is Head unit from a 2008 Dodge Viper....... Older amp with only 4 channel outputs.
I would like to run RF - RL - RR - RL. and still power a 10" dual coil Sub, retaining the adjust ablity of the four corners adjustment. All off one single 1200 watt Amp Is it possible.?????
One solution would be too. boost the Head unit siginal to power both Amsp... As the siginal would be weak spliting off to two different Amps
Pic is my 48 Divco
Pic is my 48 Divco
You can add a line driver to boost your output voltage
Recommendations ? Just need one to do the job, but not break the bank! ............... By no way am I an Expert in any means. or have clue !......... Thank you for you reply.
Like this ........... Amazon ................https://pac-audio.com/catalog/audio-interfacing/ld-10
Would I install the to the second Amp, or install right out of the head unit splitting off to each amp ! Again Thank you for the help.
at that price dude, just buy an aftermarket head unit. Factory head units are poorly made and RCA outputs are 10x better than boosted sh*tty speaker level signals.
jvc 340bts for 60 dollars will make everything sound 10x better and make your sub hit properly.
Pic is my 48 Divco
Is it the Viper radio with GPS ?
CRX: I thank you for your help. I do appreciate it !
Here is what I have
#1 AMP Plye 600w 4 Ch 4/3/2/ch
#2 amp Alpine 200w mfp-f200 4/3/2/ channel
The reason for Bootsing Pre Amp signal, is that the #2 Amp has a wire run on 18ft to back of the Divco
Would be using the Line Booster's Pre Amp.. Between Head unit and both Amps as the siginal is split too each amp.
It would be Head unit -Boosters - split to each amp - RCAs from each amp to speakers
Jeffdachef
After Market Head units are **** ugly. No after market radio goes with styling of the Interior. They look like a sore thumb !
It's hard to find the old fashioned stuff anymore actually. Glad the new unit has the features you like. In future I'd always suggest calling up...
I tried to find a sense wire on mine and couldn't. Maybe I'm missing something .I'll see if it has a temp sensor .I'm trying to get up to around...
982
Odds are that the factory subwoofer isn't going to be able to handle any more power than whatever they put to it at the factory and you would...
264
divco13
divco13
nsb
Louisiana_CRX
SlugButter
    May 4, 2024
slater
    May 2, 2024
