Boomintahoe
[quote name='Boomin_tahoe']@los33 What causes a "hollow sound" when the vehicle starts up then goes away after a min or two when engine gets warm? I noticed this on my s10 also.[/QUOTE]Depends on what the hollow sound sounds like and what engine you have.
Sent from my SM-T377P using Tapatalk
idle air controller
idle air controller
The lac aka map sensor wouldn't make such a noise.
The engine ******* way more air during startup could be from a air leak or loose headers.
If you mean hollow as in it sounds like a huge gust of wind when accelerating then that's normal and has to do with weak exhaust pipes that need to be tightened or replaced.
all fuel injected vehicles have a form of idle air controller or idle air valve it limits the airflow for a time after startup to richen the air fuel mixture. without hearing it i cant say 100 percent for sure bit most likely thats what it is and its normal. its basically a fi choke
los33
Car Audio G
los33
Houston, TX
wew lad
vegang
vegang
