Bolt and nut speaker box terminal question
Villainstone
I really dont know what else to call them but anyway. I have seen several times ppl using bolts and nuts for the box terminals. Basically drill two holes in the back of the box and put in 2 bolts with wires w/ring terminals from the speakers to the bolts. Then on the outside of the box wire and ring terminal to the ends of the bolt protruding from the box. I added a pic I found online.
The question is, is this a better design than just drilling one hole for the speaker wire and silicon it?
I use allthread, then nylock nuts and then crush washers and wing nuts.
BUT I use one stud per coil. So for each of my subs there are 4 terminals outside the box. Then I have little jumper wires so I can change the ohm load from outside the box.
Makes it a 10 second job for me to swap from .5 to 2 ohms.
I also put wood glue on the studs where they pass through the box to act as a sealer, plus the washers. Never had an issue. Try not to use stainless as that has more resistance than normal steel, and if you can afford it look for copper stuff. I did not bother with copper personally.
i always run speaker wire into the box with silicone, you can't really get a better connection than copper to copper. i personally don't like the idea of changing metal types between sender and receiver.
you know what now that you mention it. Im in aviation technician school and dissimilar metals can often cause corrosion. Im glad you mentioned that or I never would have remembered lol. I mean it will take a long time for corrosion to occur but it can happen lol. But if I can find copper then I will
stainless steel works just fine, won't add any resistance. have used them on a million enclosures.
Use 1/4-20 bolts/flat washers/lock nuts. Juse a 1/4" drill so it's tight in the hole. Won't need sealer, especially on a ported box since it has a rather large air leak already....
Im weary of using stainless as well although I'm sure it doesn't matter as mlstrass noted. Copper is hard to find but as mentioned before, brass is your next best bet as far as conductivity goes..
Wow...I haven't seen that pic in a long time.
That is from a 2-L5 15" build I did in a Ranger over 10yrs ago. I guess you stumbled across my old CarDomain page...lol
To answer your question, pretty much the only reason I use this design is to rewire subs to different loads outside the box.
Thats awesome what are the odds that the random pic I chose would be a member from here lol. Especially if its a ten year old pic. It also goes to show once you put something online its there forever.
Id seal the bolt hole up with Silicone and maybe look into placing some Poly Fill inside the Plastic enclosure and mount the new sub and run it...
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
128
160
Villainstone
Villainstone
Boonville, NY
Villainstone
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
