Boat System questions
anb.osu
Ohio
Hey all,
Bear with me on this as I have several questions that I have tried to get answered from others with moderate success.
I am installing a system in my boat. The boat is an I/O 5.7L, (basically a 350 chevy motor)
I already have a head unit and two speakers and have been planning on adding up to four more speakers km620's, and two skm10's subs.
I have now started to worry about power consumption because a lot of the time music is needed while beached, or floating without the motor running (so off of the battery) I have a PLMRA620 amp
http://www.pyleaudio.com/manuals/PLMRA620.pdf
see link for specifics, but it is a 2000w 6 channel amp, if I go with the six speaker two sub configuration then the amp will power four of the six speakers and the subs, and the head unit would power the front two. The other way the amp would just do the two speakers and the two subs....
I don't want to have to spend mega bucks on a deep cycle battery, but I would ideally like to be able to run the stereo for at least an hour without issues. I plan to add a second battery dedicated to the stereo.
1. What kind of play time should I expect, and if I want longer play time should I dial back the numer of speakers, say two speakers and one sub on the amp and then the two from the head unit. (I want some thump, but I don really need to be killin it, I just got two because of symetry more than anything)
2. When grounding the amp, I don't have a chassis ground, and have been told just to ground back to the battery..... any issues with this... (BAttery is only about 4 ft from amp)
Thanks for any help, and I am sure i will have some folllow up questions so bear with me.....
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Boats don't need two batterys. Even if you have two, they are in parrallel, and the overall system voltage drops together, but the Ahs available will increase. A very good idea though for boats with multiple large accessories (trolling motor, sound system, depth finders, fish locators, marine radios etc.)
The main problem with boats are their weak charging systems. A large engine like that is very close to what a car or truck has for electronics, however, it has a very small alternator and you should build your system accordingly.
If you have the cash- add a second battery, and see if you can find an alternator to go on that engine. With two batteries- the postives are connected, and negatives are connected. Even though you don't have a "ground" the negative of you battery is where you will connect your amp ground. The only difference is that vehicles have the negative tied directly to their chasis, and a connection made to the chasis is then connected to the negative terminal on the battery.
Boats don't need two batterys. Even if you have two, they are in parrallel, and the overall system voltage drops together, but the Ahs available will increase. .
Not to get into a pissing contest but not all boats with multiple batteries, or two batteries in this case are together in parallel. Only 4 of my 6 batteries are wired in parallel, all depends on your needs and the cranking amps required to start the engine.
--JK
--JK
You have two batteries just sitting in the boat hooked up to individual electronics I would assume? I wouldn't call them part of the system, since they are not being charged.
Other then that the batteries would have to be in parallel. The postive of your charging system would be connected to all batteries, and the negative too.
The batteries don't necessarily have to be in a line, hooked up with wires running to each battery to the next for them to be parallel. If the positives are the same point electrically, they are parallel.
Also, even if you have two alternators, with a battery on each one, they are parallel. The negatives are the frame and/or housing of the alternator, and by being bolted to the motor have the same potential- call it 0 volts, the postives then have the same potential of +12 volts.
Not really, all depends if you have an on board battery charger and if so how many bank charger. I have some batteries wired together to get the necessary cranking amps because a huge 8D battery is a pain to work with. On my boat i have the cranking batteries wired together with 2 banks of the charger charging them. I also have a house battery and a battery for the generator. Add in all the on/off/all switches and I have many different options on how to charge them or run them together if I ever needed to. I have the genset alternator, the alternators on each engine and a 3 bank charger.
JK
Sharing a common ground does not make them parallel. You could have a 18volt alternator and a 14volt alternator both charging separate batteries and both using the frame as the ground, if one alternator fails it's battery will not be charged by the other alternator or battery, and it will not be drained by the other system.
Not at all. When I used to work as a boat mechanic, often times we'd have one battery working all the accessories, and one battery just for cranking, the only thing they shared was a ground. But the accessory battery could completely die, and the boat would still start. People are careless when they're having fun, so it's a fail-safe. If any boat mechanic wires the batteries together, they're idiots. A few times I even installed a back-up third battery in case the one for just cranking died, he had a back-up so he wouldn't be stuck where ever he was.
But, the alternators on the engines (outboards, mainly) are only like 40-70 amperes. I do agree that the charging system is weak. If you have an inboard motor, then you can easily pop on an after-market type of alternator, or even more. Just my $.02. Talk to your boat mechanic about it.
Thanks for all the responses....
I am looking at 100 amp altenators for less than 100 bucks new...
Now... the main question is how much play time can I really expect to get with the motor not running, (i know it varies with output/volume and such) but am i crazy to want 1-2 hrs of play time off of one or two deep cycle or dual purpose batteries?
The Isolator system I am looking at charges battery 1 first and then battery 2. I was thinking of maybe moving up to three batteries with 2 of them being "battery two"
Ill throw in my 2 cents here i have a 20 ft open bow power boat with a 6 banger I/O. Boat came brand new with a single battery setup and I considered adding a 2nd battery and an isolator right away when doing the stereo system
I run 75x4rms into my speakers and 300rms into a sub. I play the system at prly 3/4 its output with the boat off for close 1.5-2 hours at a pop and the boat fires up every time allthough I am probably pushing my luck. IMO get a nice 2nd battery isolate it from ur starting battery and rock on
I see now how you could wire them without being paralleled, however with only one charging device they would have to be parallel. A bank charger may remedy that.
There is no question you are going to need at least 1 more battery..i would go with 2 extra batteries because there is nothing worse than drifting around on the lake with a boat that wont start...I have had a boat all my adult life and have been stuck several times and it ***** ass..get all the battery you can afford.//content.invisioncic.com/y282845/emoticons/titanic.gif.8089b7552c370bcc138aa121756d0c0b.gif
You should go for the biggest alt and batt bank you can resonable afford and fit. You'll need at least 1 spare (2 would be better) batt on a battery isolator. 1 spare (2 total) will give you about 30 min at about 400 - 600 watts, for 1 hour you'll need at least 2 just for the audio. Skip the pyle gear it's crap and it won't last 1 year. Alpine marine or PDX would be best.
With a 160 amp alt, 1 main battery, a battery isolator and 2 acessory batts you should be able to achive your desired 1 hour run time and still have a fresh batt to start your engine.
Use class D amps because the are much more efficent on power consumption. The subs will eat the most power by far. Using larger drivers will increase efficency withou increasing power consumption. For example a single 15" sub will put out as more bass for less power than two 10" subs. The box size may not be practical but maybe a pair of 12's instead of 10's would be better. More bass for less power. 6 1/2" or 6 x9's for main speakers instead of smaller speakers will also give you more sound for less power.
anb.osu
anb.osu
Ohio
DidUHearThat?
slater
    Oct 4, 2025
    Oct 4, 2025
