Hey all,
Bear with me on this as I have several questions that I have tried to get answered from others with moderate success.
I am installing a system in my boat. The boat is an I/O 5.7L, (basically a 350 chevy motor)
I already have a head unit and two speakers and have been planning on adding up to four more speakers km620's, and two skm10's subs.
I have now started to worry about power consumption because a lot of the time music is needed while beached, or floating without the motor running (so off of the battery) I have a PLMRA620 amp
http://www.pyleaudio.com/manuals/PLMRA620.pdf
see link for specifics, but it is a 2000w 6 channel amp, if I go with the six speaker two sub configuration then the amp will power four of the six speakers and the subs, and the head unit would power the front two. The other way the amp would just do the two speakers and the two subs....
I don't want to have to spend mega bucks on a deep cycle battery, but I would ideally like to be able to run the stereo for at least an hour without issues. I plan to add a second battery dedicated to the stereo.
1. What kind of play time should I expect, and if I want longer play time should I dial back the numer of speakers, say two speakers and one sub on the amp and then the two from the head unit. (I want some thump, but I don really need to be killin it, I just got two because of symetry more than anything)
2. When grounding the amp, I don't have a chassis ground, and have been told just to ground back to the battery..... any issues with this... (BAttery is only about 4 ft from amp)
Thanks for any help, and I am sure i will have some folllow up questions so bear with me.....
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
