BNIB SoundStream DTR4.500 $105 shipped
Power output:
80 Watts RMS x 4 @ 4 ohms
125 Watts RMS x 4 @ 2 ohms
250 Watts RMS x 2 Bridged @ 4 ohms
The worlds first vertical automotive stereo amplifier
Gloss black finish w/ brushed accents
Double sided pcb w/ smd components
aluminum alloy heat-sink
Regulated mosfet pwm power supply
Three-way protection circuitry (thermal, short, impedance)
Delayed on/off circuit
Variable crossovers (hpf/full/lpf)
Variable bass boost
Variable subsonic filter
Variable phase control
High level input
Signal-to-noise ratio: 92dB
Damping factor: >200
Signal voltage: 200mV-5V
Harmonic distortion: 0.50%
Dash mounted remote gain control
Direct wire 4ga. Power 8ga speaker terminal
60 amp Fusing
Dimensions: H: 7.5" x W: 3.375" x L: 15.875"
KnightWhoSaysNI
KnightWhoSaysNI
Oregon
KnightWhoSaysNI
