blue top optimas...
I pan on doing the big 3, 1/0ga, adding two batts, I saw what seems to be a good deal on these. Im going to run a aq2200 and either a 15" omega or btl...
blue tops are exactly the same as yellow tops (other than the color) and carry a better warranty!
The part you said about them being the same is correct, however the warranty is also identical.
he jus quoted me $230 for two d31 blue tops, Im thinking I should take it...
If they are new or gently used and in good condition, that would be a good deal.
I just checked, you are correct. The guy at the All Battery store lied to me......//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i'm running 2 interstate marine batteries....they work just as well as the optima's and cost alot less.....retail is 72 on the interstate and have a 30 month warranty...optima has only 18
YESSS!!!! i am running the interstate deep cycles as well. good to see someone else shares the same logic. have two along with my regular interstate starter batt. optima's are good, but why pay more for just a different interstate batt unless you need the sealed aspect of it for crazy mounting and what not....
You guys know that is a pro-rated warranty right? You will end up paying more than full price for your warranty replacement after the free replacement period (12 months) ends because they base it on full list price. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
KyngHype
Bass head to SQ convert
KyngHype
Las Vegas
loopkiller
