blown RE audio mx12
marcin93
RE audio MX 12" D1
sold as-is, has a blown coil, other than that it is in perfect condition, looks like new. Only used for about 4 months with about 1000w goin to it.
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm
Nominal Impedance -Znom: Dual 1/2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
Mounting Depth - 10.25"
Mounting Hole Diameter - 11.5"
Overall Diameter - 13"
Bolt Hole Circle - 12.25"
Motor Width - 8.5"
Motor Depth - 2.5"
Basket Depth - 7.75"
Displacement - 0.19 cu. ft.
Weight - 33 lbs.
130 shipped
shipping from 06037
marcin93
marcin93
United States
iLLsT0LZ
